1) What compression setting do I use if I am capturing footage with an ADVC 300 directly into my 13" macbook onto an external firewire drive? I will then be importing this footage into Final Cut Express HD 3.5.
2) Is this the best way to go about converting and capturing using the ADVC? I only have one firewire connection on my Macbook and I didn't have success with the ADVC connected to the external drive and then the external drive connected to the macbook. Do I need a fire wire hub so I have both the external drive and the ADVC connected to the macbook? Would I then be able to capture directly with Final Cut Express onto the external hard drive?
