I'm using ULead software to capture VHS -> ADVC-300 -> FireWire -> AVI. This probably isn't an ADVC-300 problem, but I'm not sure about that; figured I'd ask here anyway.
When the capture is in progress, , I frequently get the error message below in the XP event log. It seems that the Firewire bus is resetting itself, which stops the video capture.
When this happens, the Imaging Device in the XP Device Manager disappears. In a few seconds, the device reappears and I can restart the capture.
I have a SIIG FireWire 800 PCI-32T card, using the Microsoft Firewire 400 drivers. The Capture Service in the event log is operated by this InterVideo file:
C:\Program Files\Common Files\InterVideo\DeviceService\DevSvc.exe
Having capture sessions interrupted 10-15 times a day is a MAJOR pain in the neck. Any suggestions?
Event Type: Information
Event Source: Capture Device Service
Event Category: None
Event ID: 0
Date: 7/20/2007
Time: 6:57:51 PM
User: N/A
Computer: ***
Description:
The description for Event ID ( 0 ) in Source ( Capture Device Service ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: [CDeviceServiceModule::RemoveFromMap]:
Removed device name Microsoft DV Camera and VCR
Event ID: 0
Date: 7/20/2007
Time: 6:57:51 PM
User: N/A
Computer: ***
Description:
