HDSC1 Question
  • HDSC1 Question
    Does anybody know what the HDSC1 does to the 16x9 aspect ratio on the SD down-conversion? Does it stay 16x9 or can you get 4x3?
    ADVCHDSC1 doesn't up/down-convert.
    It does HD-SDI -> HD analog
    and
    SD-SDI -> SD analog
    As I understand it, aspect ratios are preserved, regardless.
      Oops. You are absolutely correct. I should have read more closely rather than just look at the back panel. Thanks!
