I'm trying to capture a bunch of grainy old VHS home movies that were dubbed using very low-quality cables and a low quality VCR from Sony 8mm to VHS in the early 1990s. The tapes definitely display some color banding and flickering (flashing rainbow effect), and I'd hoped the ADVC300's "3D Y/C Separation" would help clean this up.
However, the VCR I'm planning to use for playback has S-Video outputs, which, while theoretically higher quality than composite/RCA video, CANNOT make use of the ADVC300's Y/C Separation (because S-Video already carries the Y and C separately).
Here's my question: Would I get better cleaning up of the VHS tapes if I used COMPOSITE instead of S-Video cables?
The Sony 8mm tapes were originally dubbed to VHS using low-quality composite cables, so I'd imagine they suffered a lot of damage as they were written to tape using the low quality VCR.
If by using a composite cable instead of S-Video to transfer the tapes to the ADVC300, would the "3D Y/C Separation" undo some of the damage done by the ORIGINAL composite dubbing?
Thank you.
Thank you.
