ADVC55 / red LED / Premiere not capturing
  • ADVC55 / red LED / Premiere not capturing
    Hello - I used to have a functioning ADVC55, although it is somewhat temperamental depending on settings. At the moment I can't seem to get it working. Here are the stats:
    Model: ADVC55
    Switches: 1 and 3 switched to on
    Connections: VHS > ADVC55 > Firewire / tried both motherboard and front card
    Firewire cable: tried a few differet ones / combinations
    LED Light on ADVC55: Red
    Software: Premiere XP Pro / mode Capture / DV Device control OFF
    ADVC55 power - mains electricity
    Cables: VHS > ADVC55 - Svideo, 2x audio phono
    Just looking to capture sound from a VHS cassette that has a black picture
    Problem: Timecode not moving / sometimes moves / sometimes freaky numbers. Press record, looks like it is capturing, but captures null frames, and thus no file.
    Symptoms: Can't see a picture in the preview window with other VHS cassettes nor sound.
    Other DV devices capture ok using firewire.
    Any clues?
    Have you tried turning on Device Control?
    The ADVCs aren't like other media converters. The ADVCs really "look and act" like cameras.
    Thus, an ADVC usually won't start free-running timecode until it receives a DV Play command. In some cases it will if a video input signal is present when it starts up, but for predictable results, turn device control on.
